OK I posted here about a week ago with thoughts of selling my car since I needed a DD for college. I have definately made up my mind of keeping the car throughout college. So to do that I want the car in tip top condition. So I am going to list some things I need some opinions on to button the car up. I just started my car for the first time in a week I would say and it is about 40 degrees I am guessing outside right now,maybe 50 IDK but anyways, she STARTED RIGHT UP! I am having it warm-up right, just idleing. I have my room window open and the car is just out front so I can see it also. WOOT! Music to my ears! Anyways I am going to list what I would like to fix up.
Speedo failed now for the second time after passing 100 MPH - I do have the vehicle speed sensor code BTW if that matters but I dont think so since the speedometer is cable driven.
I have a brake leak that I think I am going to try and fix today, since the new line came in earlier. My brake booster/master cylinder is going out on me. Right where the two meet, there seems to be what sounds like a vacuum leak.
Have no turbo pressure what so ever, also threw that code, I looked over the IC pipes but didnt see anything visually, could there be a tear in one of the pipes. Or maybe I just missed it. Dont have air compressor as of now, on the list to get though.
Knock sensor code also was thrown. Need to rewire those puppies.
As I am listening to my idle, I can hear a rattling noise but with a higher pitch to it with the rev of the motor. Its up by the fan. I think it may be the timing belt tensioner pulley. I think I will regret not replacing that when I did the build. AHH.
Valve lash Definately! When I put in the SS Spark plug Galley a few weeks ago. I couldn't even slip a 0.038 feeler gauge in between the came lobe and the shim. Is that normal? I think I may need smaller shims or something along those lines.
Timing is around 10-12*
Vacuum is 16-17"
My idle after the car is warmed up, kind of bounces around. Has a little miss to it.
The Bird has been gone since day 1! Ive added cooalnt to the overflow tank and it the cage light just seems to stay on.
I think that is all I can think of for right now. Just trying to get the Car drivetrain in tip top performance. Maybe this could be my DD. Anyways I will have to get a video up sometime later on this week. Please give me some advice on what I have listed so far. THX IN ADVANCE.....
Vacuum is 16-17"
