Just a few questions, hopefully you can help,
here is my VIN# JT2MA71L4K0109444
my VIN# says my car is an 89
however I do not know the manufacture date- the sticker is no longer there.
On the Apexi wiring diagram there is an entry in the Supra category that has year 88.8 by itself and has a remark that says "Turbo A" next to it, and has a different sensor type completely.
Would that be my car?(Refer to picture of chart below) or should i hook it up like the 88.9-90.7 Karman sensor?
Also, In my pin diagram, there is a pin named "Turbo A Pressure signal" and I am not sure what color SAFC wire should be connected to it.
The grey wire is attached to Throttle Signal, and green to RPM Signal 1, The Orange/pink are connected to the Airflow signal, red wire to IG wire, purple to Knock signal 1, and the grounds are connected.
This leaves me with a Blue wire, a white wire, and a yellow wire......did i do it wrong? What does this Turbo A Pressure signal hook to!? I dont even have a wire in that spot on my ECU harness plug....just an empty hole.
