a/f problem!
CarlosPTR210
435
Calexico,CA
www.ptr.com.mx
Hi Guys,
First, please don’t reply this post because my poor grammar skills:cry: .
Ok!,
I have some problem with my A/F ratio, if I boost with out a WOT condition my A/F ratio is around 13-14:aigo: , but when I boost at WOT my a/f change to 11.
What can I do:1zhelp: ?
I have a Lex and 550 injector, AFP regulator and a Apex AFC?
Thank you all
Boost Lee
Bee Doo Bee Doo Bee Doo
2,750
Indianapolis, IN
CarlosPTR210 said:
So is normal???:icon_bigg
:rofl:
I don't know why...but the impression I got from the way you put that was kind of funny. Sounded like a little retarded kid that found out he wasn't really retarded? :naughty:
Anyways, that doesn't sound "perfect"...but definately doesn't seem like anything is wrong...
+1 for being overprotective on your Poopra. ;)
Jeff
dbsupra90
toonar
indiucky
CarlosPTR210 said:
Yep, the problem is:
the thing leaner than 12.5 under boost @ any throttle <60%
could be a air leak?
nope thats the car doing what it was designed to do. anything less than ~75% throttle it is running closed loop. in closed loop, the ecu tries to maintain 14.7:1 a/f.
aljordan
LEADED FUEL ONLY
Jul 14, 2005
466
Indianapolis, Indiana
www.apeserver.com
Just drive the car and let the ECU figure things out. There is nothing wrong with the car. It is running just as it was designed.
You are unable to tune any condition that is in closed loop. You'll make a change, and the ECU will do whatever it wants.
