:1zhelp: HELLO EVERYBODY
I FINALLY GOT MY SUPRA UP AND RUNNING IT TOOK A WHILE BUT IT S DONE
I STILL HAVE A PROBLEM WITH THE CAR
1. THE CAR IS RUNNING VERY RICH. (DON'T KNOW WHAT TO LOOK FOR ? MAYBE TURBO MAKING IT RUN LIKE THAT ? TIMIMG IS CORRECT.
2.OIL LEAK AT VALVE COVER (FOUND OIL IN PLUG ALLY) HAS NEW GASKETS AND SEALS ALL OVER JUST REPLACED HEAD GASKET,W/ PUMP ,TIMING BELT,TENSIONER,.ETC.
3. THE SPEEDOMETER DON'T WORK .WHAT CAN IT BE?
4.THE A/C DOES NOT WORK,REPLACED A/C COMPRESSOR AND RECHARGED WITH R-134A FREON,YES I DID THE CONVERSION BUT IT DOES NOT COME ON EVERYTHING INSIDE CHECKS OUT OK,FUSES GOOD, RELAY GOOD,WHAT CAN BE THE CAUSE?
PLEASE IF YOU HAVE RUN INTO ANY OF THIS PROBLEMS BEFORE AND YOU FOUND A FIX FOR IT CAN YOU AT LEAST POINT ME IN THE RIGHT DIRECTION?
I REALLY WANT TO DRIVE THE CAR BUT WITH THOSE PROBLEMS I'M AFRAID I WILL CAUSE MORE PROBLEMS IF I DRIVE IT LIKE THAT......HEEEEEEELLLLPP!
:1zhelp:
:1zhelp:
