A clutch ?tion
Ymh
120
Oklahoma
My clutch "catches" at the very very top of the pedal, is there any way i can adjust it to "catch" more in the middle of the pedal? if so how?
loki2043
645
Portland, OR
your clutch is shot. time for a new one!! its an auto adjusted clutch AFAIK. when was the last time you replaced it? what happends when you hit about 4000 rpms and dump it? slipping?
drbowser3
The Doc is in...
Jan 17, 2006
215
Tampa,FL
You can adjust the pedal, but most likely the clutch is on its way out, when I bought my 89' it was the same way. It is a threaded rod right off of the pedal under the dash, its a bit of a PITA to do it.
