A/C wire for 1JZ
wht95scort
NJ
I'm keeping the a/c and am not sure where this single blue wire goes off the 1JZ harness. I have the a/c plug that comes off the harness plugged into the compressor but there is a single blue wire off the harness marked "a/c" Any ideas where this goes?
JonoTurbo
Going for broke
CT
It's the AC magnetic clutch wire. It runs through EA2, is that wire from the body side or the engine harness side?
JonoTurbo
Going for broke
CT
I told you what it is, and where it goes. What are you looking for?
It runs from the compressor through the EA2 connector on the engine harness to below the fusebox where the AC clutch relay is. If you look you should have a single pin plug with a blue wire on it below the fusebox which connects to that wire.
wht95scort
NJ
Ok, I get what your saying and today tried to find the relay you were talking about. I didnt see it but did see many blue wires? Heres a pic of the area.
