A/C Problem
ians13
537
Jacksonville, fl
Well I fixed my A/C a short time ago, now when ever i turn it on my idle drops from 700rpm to 500rpm i know that the idle should go up or atlest hold the same idle that should be controled by a load switch some were, i just wanted to know if any one has this problem. and were can i find the ac load switch or what ever controls the ac load idle.
8,895
51 comes up if the A/C switch is on. If you push the button, and don't get 51, then you know why you have the low idle. The A/C signal is not reaching the ECU, which is why you do not have the command.
But you need to see if you have 51 with the A/C button pushed in.
jdub
Feb 10, 2006
10,730
Valley of the Sun
I knew this was where you were going...very nice Nick :bigthumb:
ians13
537
Jacksonville, fl
ok i'll try this and see what i get, lets assume that the signal is not getting to the ecu, it would have to be getting a signal from one of the sensors in the high pressure line. am going to have to investigate this.
mrnickleye
Love My Daily Driver !
Jun 8, 2005
825
Mojave Desert, Ca
Turbo......PG 4 in the AC section of TSRM shows a wire from the AC amplifier going to the EFI?
http://groundsky.co.nz/techinfo/TSRM/24_AC.pdf
PG 6 also. "to EFI"
This would be the signal that tells the ECU to up the idle.
Last month we had a truck with a burnt amplifier. The ac would not work. After installing a new amplifier, all was fine, including the idle up.
Inside that one was a small relay that finally cooked.
Our cars are a bit different, but this info may help you.
8,895
ians13 said:
could this also explain why my ac does not work on low speed.
i'll check this out this week end.
Elaborate on that a little more please. The fan is the issue, or the air is not cold on low speed?
johnathan1
Supra =
Aug 19, 2005
5,056
The idle problem is either the A/C amplifier (or wiring to it) or the ISC. Check by pulling codes with the A/C button pushed in like Nick said.
The fan speed problem is likely the resistor pack in the passenger footwell.
