ok, my car has never had an air cond compressor for the entire time that I owned it. When I bought the car, it was simply not included. The lines were plugged and tapped off.
I recently aquired an AC compressor, and did the install
I replaced all o-rings in the system, replaced the dryer, put flush through the system and blew it out with my air compressor. I pulled a vacum on it, and it held for 2 hours. I then charged the system to TRSM specs using gauges and a 30lb drum of 134A.
The problem is, I don't know where to hook up the one wire plug coming off of the compressor. I found a power source to run the compressor for the charging. I used the blue wire on the two wire plug hanging down close to the A/C compressor. The compressor I got has a spade terminal on the wire, but no plug around it. I assume that the correct plug on the car for this is the small white single terminal plug between the battery and the fuse block. It is sticking out of a taped harness about 1-2 inches. The compressor wire reaches it perfectly.
When I plug into this, and set A/C to max, I get nothing. The compressor doesn't run at all. I have no voltage at this wire.
I also tried to jumper both high pressure switches on the passenger side fender wall.... didn't do anything either.
I have read the entire A/C section of the TRSM.
Any suggestions on where to start looking? It blows ICE cold when hooked up directly. I would like this to work, because the defogger works sooo much better, and we have really warm days here during the winter on occasion.
So, any suggestions on what to look to first?
