Morning all,
I have a 88 T that is fairly stock. I ran into A/C issues. The system has a full charge of R12. There is a 10A fuse on the passenger kick that keeps blowing everytime I turn the A/C on, keeping the compressor from kicking in.
As you look down on the engine, there are two schrader valves below the turbo. I disconnected the low pressure switch. Oreilly Auto Parts sell these valve/switches cheap, around $10. I'd like to replace it to see if that is the cause of my fuse blowing.
My question is: How? There is a nut looking thing on the top and a bigger nut looking thing on the switch. I assume I put a wrench on the smaller one to keep it from moving and unscrew the larger one. Assumptions are a bitch and there is some rather expensive R12 at risk.
Any help?
Chris
88T Auto
cjones55555@yahoo.com
Any help?
Chris
88T Auto
