93-98 Supra Factory Stereo in Mk3
turbo
Mr. Clean
Apr 27, 2005
135
Calgary
Has anyone put a stereo from a 93-98 supra or any other nice oem toyota/lexus stereo into an mk3 supra?
Geoff
supra90turbo
shaeff is FTMFW!
32
MA, 01440
I thought about this before. Placing an in-dash 6-disc changer from a newer Toyota in my car. I believe I remember reading that it's a fairly simple operation... someone step in here. I know I wouldn't have thought of it if it were harder than putting an aftermarket cd player in...
Suprastic
727
Manitoba
I wont be hard. Both cars have a double DIN slot, but the wiring harness will be different. Easy fist though. If you can get the male connector off a MK4 then you can spice it to your factory harness on the MK3. You'll also have to find out what speaker wires on the MK4 since it'll have 6 or more speakers. Even then, you might only be able to get 4 speakers instead of 6 unless you have a 6+ (89+ cars) speaker system. Not hard.
suprastanger507mgte
2x88+2x89+1x91+2x92=ME
Hayward , Ca
If you buy one of those Scosche wiring and it shold not be any problem. The har ness is almost the same.
turbo
Mr. Clean
Apr 27, 2005
135
Calgary
I have a 1990 car so I guess I have 6 speakers and the wiring harness plug looks identical with the same number of pegs. It looks to me to just be plug and play but any more info would be great.
supra90turbo
shaeff is FTMFW!
32
MA, 01440
Make sure the 12v constant, ACC, and ground are in the same pins on either connector, then just plug it in and find out if they're all the same.
+1 on the navi. forgot about that!
jester1341
topless and blown
Western Maryland
i was going to put a cd/FM/AM double DIN unit from a '01 celica into my 87T but i decided not to since i had a SONY and got a free SONY changer[mounted in the arm rest ;) ].
john
92turbo4life
1,289
wherever
well i got a alpine unit for like 50 bucks from my friend....
hooked that up to a 12in alpint typr r <ricer:)> speaker and a 1200 jl amp!
thing rattles my throat i just dont like how the 12 sits in the hatch all big n gumpy looking lol
bluepearl
326
pa.
I got a radio from a 97 in mine, mostly PNP. Be careful, newer style toyota radio's wont fit. They are a differant size.
isnms
United States of America
Oklahoma
i80.photobucket.com
Mine has a not stock unit. It's a Toyota unit. All the connectors in back connect up.
vbpicgallery.php
Suprastic
727
Manitoba
Only one problem. The Scosche and similar harness' are female connectors. You use them so that you don't have to butcher your existing harness. Unless you thought about getting one for the MK3, then splicing the MK4 harnes into it. The all you have to do is clip it in to the factory harness and in the deck.
Justin
Speakers?
Spokane, Wa
unless you get a radio that was part of a factory amplified system, the wiring harness will be identical.
Toyota has not changed their wiring harness (non amplified) since 86. the color of wires are different, but that's all.
Jeff Lange
Administrator
4,919
5
Sunnyvale, CA
jefflange.ca
Toyota has used the same plugs from 1987-2000, and on most vehicles post-2000. The 93-94 Supras used the exact same stereo as the 92 Supra (same part number), later models will also go in without any modification.
The only exception is if you're putting it into a car that didn't have the external amp, you will need to get the external amp and wiring harness from the dash to the amp (under the passenger seat).
