Here is my restoration with pics... goal is to restore everything I can possible...
Just got the head back from the machine shop... total at the shop was $408 and they did cleaning, pressure test, replaced all the valve seals, re-seated 2 valves, and milled off .006" off...
So far, got a new water pump, new radiator, OEM head gasket, ARP studs, and top end cometic gasket set... along with all the fluids and other little things required.
The intercooler hose is horrible and wondering if it is worth replacing or just going for a drift motion intercooler kit?
