All right so this hasn't been updated in a while because I just got engaged and spent all my car money on a ring haha.
But now that is all taken care of i'm back to work on the car. So here is what happened so far.
This was my supras last drive with the 7mgte, still runs and everything but my tags expired jan 1st 2013 so we took her for a spin then covered here up and put it away to await the 1jz.
While taking the tranny off the engine I got found this exedy hyper clutch kit
fly wheel and pressure plate look good so I think i'll just order a new disk for it.
All ready resealed most of the engine, including front and rear main didn't take many pics of all the seals.. boring stuff
(that's my friend Ben in the pic, also doing a 1jz in his mk3)
While doing seals and had it broke down painted it
.. for some reason I took pics of the prep and primer but forgot to take pic painted.. it's glossy black now.
Polished the intake manifold
BC cam gears and 264 cams
Pulleys/spark plugs
Got new timing belt put on, new water pump, and test fitting everything, all the bolts are hand tight, still need to take most off and clean the head with a tooth brush
The woman holding up the cam gears so I can decide what color to do my valve covers, I think i'm going to match them to the cam gears, then run an aluminum spark plug cover
So that's where i'm at right now.
I just ordered a drift motion top feed fuel rail, engine dynamics 1000cc high impedance injectors for e85, and a new alternator. Should be here next week.
My next step is to install cams and cam gears, get my powder coating done on the covers, and clean the head. Also still need to polish my water neck
This should be updated often now sense i'm aloud to work on it again lol, and it's almost spring and I need something to drive this summer that is fun!
If anyone has a new upper and lower intake manifold gasket let me know! I don't want to order a whole seal kit from driftmotion for 320 bucks when I Just need those 2
