90T Strange starting Issues!!!!!
S
supra91t
Guest
91T with HKS Turbo Timer and cut-off alarm.
There appears to be a couple of issues, good battery works for short while but it appears it is not getting a charge fromt he alternator. Replaced alternator three times. And battery. Removed Turbo Timer.
When jump starting car starts and runs fine then removing jumper pack will stop immediately. Occassionally the lights in the dash will flicker rapidly. All wiring to starter etc appears fine including grounds. Could a starter relay cause this? Ignition switch?
Thanks for any ideas
Turf
