I also posted this over on Supraforums hoping to get an answer...OK, did a turbo conversion correctly. The car ran for several days while trying to work the bugs out. ISC was blocked off causing it to die during shifts...anyway, while playing with that, the car will no longer start.
Timing at TDC has crank at 0, cams at 12 o'clock, CPS is right, getting spark and fuel, 180+ lbs on all 6, swapped ECU, AFM, CPS, coil pack, and still nothing different. It sounds like it wants to fire up, but just spins over. Will backfire (sounds like a gunshot) after 8 seconds of cranking.
WTF happened? I've been searching all over
I need some new leads to follow. The car has not ran in 2 months...HELP!!!
