90 7mgte will not start, Putting no codes
Mk3Shogun
Tx
Hey guys, Well this is what happened i was changing my tires and proceeded to go around the block to make sure the lug nuts were tight. Started right up and went, Pulled into my car port as i was the rpms stayed at 1k while i stopped, shut off the car and went inside then only to come back out and the car will not start, every-time i go to start it i hear a wining noise and when i stop turning the key it makes a loud click. Please help thanks.
Apr 10, 2008
322
South East USA
Depending on your skills... sounds at least like starter solenoid not engaging(likely) or timing belt (unlikely).
If it was a ford you could smack it with a hammer to get some additional duty LOL
It's a supra so check connections at the starter and GROUNDS - my first take
Numba1Stuna
361
Nampa, ID
Clicking makes me think weak battery/bad alt. Maybe it's a different clicking. Can you post a video?
Sent from my LG-P999 using Tapatalk 2
peste noire
266
los angeles,CA
nvm just read it right.
If it was a ford you could smack it with a hammer to get some additional duty LOL[/QUOTE said:
hahahaha
yea what he said. check connections to battery first and if you got a volt meter, even better.
