san supra;1360225 said:
haha this is hypothetical and i said educated u nay sayers.
I just dont want the gasket taking me below stock.
quit being fucks and tell me your guesses.
i dont need your negativity!
if yall represent the supra scene then i guess i will be a loner. A forum is to help, not to be a high and mighty ass. Help a fellow supra owner.
my head and block have been decked/machined and my motor is legit.
1) Hypothetical or not this is a calcuator question, learn to use one.
2)First you said nothing was shaved and now your head and block have been machined.
3)Your head and block have been machined? I thought this wa Hypothetical, stop contradicting yourself.
4)You didnt give us the info we needed, piston type, bore, and how much was taken off the head and block.
5)Assuming pistons and bore are stock, you dont even need to calculate anything, if you want factory compression ratio, take what you took off the head and block, add that to the thickness of the factory HG and thats the thickness HG you should use. You would know this if you did a search.
This forum is to help people. If you came with a problem we would help you. But you didnt You came out rudely demanding we answer stupid questions to your liking because your apparently incapable of using a search engine, basic geometry skills, a calculator or your own head for that matter. So go ahead be a loner, take gofastgeorges advice and buy some books on performance engine building and while your at it grab a book on communication and people skills because you could use some.
Finally if you decide to stay here at SM give this a good read before you post again:
http://www.supramania.com/forums/showthread.php?p=230560
