A while back I got a set of 89+ turn signals and grills from empera, since I put on a bomex front bumper. Does anyone know what needs to be done to install them on a pre-89? When I tried there was nowhere to screw it into
You may need the little white plastic washer thing that fill the hole so the screw fits correctly. I snapped a pic, ill have up in a second.
The third and fourth pics are for teh grill. The clip part on the grill stays in the hole (left hole thrid pic) and your supposed to undo the screw from the back to pull the grill out, but hey, i found an easier way.
The metal support under the nose is different between 89+ and <88. If you really want to bolt it up properly without having to cut that one up, you have to get the 89+ one
