89 tail lights in a 87?
dirtlord420
just here
Aug 1, 2005
371
tn
i got a set of 89 tail light laying around i was wondering if i could put them in my 87? if the locks would line up? has any one did this? i know it can be done i wouldnt be that hard
aye mate
Hiatus over.
Maryland
Search! This is a very popular swap. Many,many,many people have done it.(don't know why tho'...) But yea try the search button...
shaeff
Kurt is FTMFW x2!!!!
10
Around
for common questions like this, you really need to search. this is a common upgrade among pre-89 people. they bolt right on. you'll most likely have to drill a small (1/4") hole or two on each side. other than that, it's a bolt on affair.
also, if/when you do this, get new tail light seals, and put a little RTV sealer around each hole. it cant hurt ;)
-shaeff
Stanzaspeed
2.5 Twin Turbo R
Calgary, AB
good idea. also if memory serves you will need to get an 89+ lock as the pre 89 lock dosent fit right inside. :icon_razz
shaeff
10
Around
huh? you just confused the hell out of me :p
if your car is an 86.5-88, then any 86.5-88 tails will bolt on with absolutely no modification.
if your car is an 86.5-88 and you put on 89+ style tails, then you'll have to drill a couple of holes, and as stanzaspeed mentioned, get a new lock cylander...
i'm assuming you mean:
"ok they are 89+ lights so they should bolt up to my 88..."
the answer is YES, but with some slight modification to the body of your car.
-shaeff
Stanzaspeed
2.5 Twin Turbo R
Calgary, AB
and with a bit of time swearing at the tight spaces you need to get into to bolt everything up. :biglaugh:
turbo4toy
208
Los Angeles
they are right i did it recently.... if you put the lights where they are supposed to go you will see where you will need to drill the holes for the bolts. then you just have to get a lock from a 89+ supra for the rear. I just got a whole lock set and switched them all out.
MKivSupra_Rob
INLINE6
Jan 22, 2006
288
Wpg
I got my 86.5 lock to fit FINE! just break off the little clips to hold the 89+ lock and put a small screw into the centre piece to hold it in, not enough to get to the inside, now i have no idea how well this is going to work because i painte dover my centre piece and therefore can not see if the screw is visable from the outside. But damn does the metal lick everl ook nicer then the orange one. Also it is possible to keep your old mouldings too so they still match, A bit of work but mine are looking fine.
