89 Supra Turbo ALARM PROBLEMS
Status
Not open for further replies.
supra_89_vang
95
madison
Hi experts,
I replaced my battery and than my stock alarm went off. Now I can't start my car, it won't crank and I know it's for sure because of my stock alarm system. This happen to me before and I had to wait a few weeks inorder for my car to reset. Anyone know how to reset the alarm system so I can try to start my car. Thanks
Joe
isnms
United States of America
Oklahoma
i80.photobucket.com
  • lock and shut the doors.
  • wait about 30 seconds or more
  • unlock the door with the key. try this with the other door in case it doesn't work with the first. the sensor on the back of the key cylinder may be defective.
  • get in and start it
billspreston01
555
North Carolina
Your door lock sensor might be messed up. When you turn the key it disables the alarm. It also might be the wires. From the lock there's like 2 or 3 wires that are taped to a metal rod to keep them away from the window, if those go bad the alarm won't disable. Try unlocking the car from the passenger side door.
MKIIINA
Destroyer of Turbos
Plano, TX
if you want to disable the stock alarm like we did on my bros car and fix the problem of weak contacts etc....
Pop hood.
Located black box located right next to the hood latch assembly.
Mark location of hood latch w. sharpie or pencil.
Remove latch.
Remove dust cover for wiring.
Unhook the connector.
Replace the dust cover.
Use the before mentioned marks bolt the hood latch back on.
Close hood and never get stranded again!
PS. to reset the alarm remove the efi fuse for 45sec-1 min. this will clear your codes and usually resets the stock alarm. Make sure the car is unlocked when you do this. good luck!
chriso
Supranian
Bay Area, CA
If I set the stock alarm, I have to un-set it by unlocking the passenger door first otherwise it will go off when I open the driver's door. weird.
MKIII VIXEN
733
resting
My car is doing the same thing. It hasn't cranked in a week. My wonderful husband has disconnected the wires by the hood latch, and tried to reset it, but it won't reset. You can hear a clicking sound by the passengers kick panel. Any more suggestions? We've tried everything that we could find by searching on here. Thanks.
crrider80
Too soon Jr.
Jun 3, 2006
341
NYC
to hell with the hood latch thing. if you want to start your car again, locate the little black box that says theft deterent or whatever above the steering column and unplug the harness from it. Locate the blue wire with orange stripe, strip it, extend it, and ground it. viola. no annoying factory alarm and your car starts!
-Steve
MKIIINA
Destroyer of Turbos
Plano, TX
but that ways alittle more perminant where as the hood latch is a bandaid you can fix later on.....
-Steve
I did that last week. Car wouldn't start. Two days later it started. It hadn't been touched in a couple of days and then started right up. I cut it off, and now it won't start again........................:dunno:
crrider80
Too soon Jr.
Jun 3, 2006
341
NYC
um... I did it while the battery was hooked up. i dunno if that makes a difference. Also, find a good silid ground and keep it grounded. Don't disconnect it.
-Steve
I unplugged it and then grounded the blue wire with the orange stripe, and then plugged it back in. I tried it with the plug in and out and neither worked...............:dunno:
chriso
Supranian
Bay Area, CA
I would check the key lock switches. They have a small contact ring that I've found gets a little corroded over time. I cleaned mine up on another Supra and my alarm worked great after that. Be careful taking them apart since they can be brittle.
Cedrock15
The Sarcasm Specialist
Sep 29, 2005
126
Bucks County, PA
i did the hood latch thing with mine last year, then car wouldnt start, then i cut the wire for the alarm box way up around the steering column and never had a problem after that. I recommend you do both methods.
supra_89_vang
95
madison
Hi,
I am still having problems starting up my supra. Can you please give me a more detailed instructions about completely disarming the factory alarm? I can't located the block box you are talking about. Thanks
Joe
-Steve
Supra_brothers
Super Lurker
Oct 18, 2005
TX
the older alarm systems suck mine kept going off when no one was around and when it was parked at my house i ended up taking it off because i got sick of coming out to my car going beeeeeeeeeeeeeeeeeeeeeeeeeeeep whenever it would go off i would first pull the horn then proceed to try the lock and unlock method and then reset the battery good luck
WonIt
Air ,Fuel ,Spark!
Feb 26, 2006
175
Front Royal,VA
I had the exact same problem you all are having when i first got my supra,,i tried all the methods,i finally got tired of fooling with it,so i ran 1 wire from hotside fo battery,and 1 wire from the starter to a toggle switch in the car...no more problems EVER....but be sure to get a fused line just incase it gets grounded!!! my 2 pence
Status
