I bought an 89 non-airbag steering wheel and 89 combo switch off of ebay (different auctions). Turns out the previous owner of the wheel tried to wire it to a 3 pin harness to work on a pre89. Problem is, I plugged it in to my stock 3 pin combo switch and the cruise set buttons don't work. Since I bought the combo switch too, i'm just gonna wire it back to a 4 pin (If I can find a 4 pin connector that will fit the harness).
I need a picture of an 89 non-airbag wheel's 4 pin wiring, so I can see what colors go where.
Until then, i'm gonna toy with the 3 pin wiring and try to get it to work. Anyone know how to wire the 3pin to work correctly?
Thanks in advance!
Edit: After taking the wheel apart and looking at the set switch circuit board, I realized he had the switch ground wire disconnected. Rewired that and just took it for a spin... it works!
I'll still take the picture of the 4 pin wiring though, in case I want to use the 89 combo switch
Thanks in advance!
