frontierguy25;1526061 said:Just get you some 98 Supra 2J mounts and call it a day! Stiffer than stock but ride better than poly and 800rwhp MK4's use them... I tried solid and poly before and if you dont have all good bushings your car is going to vibrate like a mofo!!
frontierguy25;1526102 said:Yes your car is going to vibrate like mine.. I've replaced a lot on my car and still got vibrations bad! Just get the 98 Supra mounts they are only $58 a piece from champion or elmurst toyota.. vendors on sf... you will be very happy you did! I'll have about 500rwhp next weekend and they will hold just fine an ride just fine too! Get the stock 98 mounts they will hold 800rwhp...
becauseican;1526484 said:BIC has solid 89+ mounts in stock. Yes the mk4 mounts work too, you just need to grind off one locating pin, IIRC the 97-98 mounts are the best.
