I've searched and tried several things, just can't get it to work. I have the NA tach in and the MSD 9210 converter with it wired to RPM1 on the ecu and then the output to my black tach wire to the dash. I have very little movement on the tach (under 1k when I give it good throttle). Maybe I have the converter hooked up the wrong way, for the other type of signal? I also plugged in my old HKS super AFC and it shows like 120 rpm around idle. I tired wiring it up to RPM2 and it shows like upper 20 rpm. Do I need to jump the resistor now on the back of my tach, or try a different wire to tap on to for my signal? Any thoughts?
