Needing to know if SC300 motor mounts (Round) will work on an 89 7MGTE? Searching I see they are more readily available and fit the budget moreso than 7M mounts...Any other recommendation??
Are they the same as a mkiv? If so yes I was reading about that earlier. I think the only thing that needs to be done in order to make it work is file down a alignment pin so that if fits flush. I think they are cheaper, but harder. Some like that they are harder and some don't.
