89+ led brake light dissasembly
3.0 GT
2JZ Holset Mafia
Nov 30, 2008
381
Franklin, Tn
does anyone know how to seperate the led brake light strip in the 89+ spoiler? mine has 3 led's out on the right side and i would like to repair them before i put my spoiler on. thanks
3.0 GT
2JZ Holset Mafia
Nov 30, 2008
381
Franklin, Tn
RazoE;1537684 said:
just look underneath, there should be a small hole for a philips screw driver..
unscrew the single screw, and the LED bar should pop right out..
i know how to get it out, thanks tho, i aLREAdy have it out i need to take it apart tho to fix some leds
RazoE
Boobs/Boost, my favorite
Jun 13, 2006
4,946
Los Angeles
www.cafepress.com
Don't think you can do it very easily. I helped take apart a Camry's LED bar and it was glued together, so we cut the plastic with a knife, and bits flew off, it was a big mess..
but we siliconed it back shut when we were done fixing it, and it's been fine since..
supra90turbo
shaeff is FTMFW!
32
MA, 01440
If it's like other tail lights, there is some adhesive holding the lens to the housing, and you have to either bake it in the oven for a few minutes or use a heat gun and carefully pry the lens (read: CAREFULLY). As it warms up, it will slowly peel apart. Be patient and try not to melt the lens or housing!
3.0 GT
2JZ Holset Mafia
Nov 30, 2008
381
Franklin, Tn
sounds good. i will try the heat gun 1st and if that doesnt work ill cut into it.
