2kV6 said:
It does a little bit. I'm trying to find the actual pinouts.
You can do it from the TEWD.
I'll give you an example....
Suppose you want the pinout of connector A35 (AC control servo motor) on page 24
http://www.cygnusx1.net/supra/Library/TEWD/MK3/manual.aspx?Section=Main&Page=24
So click on the Automatic A/C tab on the left side, then scroll through to p135.
At the top is a Parts Location table with a code column. Look for connector A35 and note that it is also designated H .
Scroll one more page and you will find a picture of the connector H. The function of the pinouts of the connector are in the actual wiring diagrams.
So on page 141 you see the "Recirc/Fresh Control Servo Motor" with pins 1 through 6 defined for the H connector (which is A35) and the wire colors.
Confusing yes, but after some practice its pretty easy to sort out.
