89 7M-GTE - Maf question - Pics!
ToyotaSupra
Shawn
Dec 12, 2009
59
Fond du Lac
ok, should i put my mass air flow housing in the #2 spot cuz it feels like the turbo has a bit of a lag
8,895
Item number 1 is an air flow meter, not a mass air flow meter. No, you shouldn't put the meter in spot number 2.
A MAF conversion can be done that way.
mkiiichip
1,434
WI
Where does the T on the BOV signal go?
Why are you using ported vacuum on the FPR? Where does the other end of that T go?
NTRA08
TWINKY
Jun 10, 2008
530
Conroe, Texas
Thats easy it goes to the true vacuum nipple on EVC
---------- Post added at 08:34 PM ---------- Previous post was at 08:32 PM ----------
your right the vacuum routing looks all kinds of fked up.
ToyotaSupra
Shawn
Dec 12, 2009
59
Fond du Lac
yea the guy i bought it from did most of the shit, i just disconnected some things that were wrong and couldnt figure some things out, the HKS EVCII i dont even know if thats hooked up right, i went off a EVCIV diagram which wasnt too clear either. i just love buying fucked up things :)~
---------- Post added at 10:23 PM ---------- Previous post was at 10:19 PM ----------
lemme go check where it goes..................... ok it goes to stock sensor assy turbo pressure, i dont know if the fpr is even hooked up cuz the gauge doesnt work that i can see.... i got this car all fucked up,,, too far to my knowledge, which is why i <3 u guys :)~ lol
mkiiichip
1,434
WI
FPR's need manifold vacuum. Youll need to reset the fuel pressure.
The 2 small lines on the TB are ported vacuum (not manifold vacuum), and are for evap and EGR, and it looks like you dont have either one, so cap those lines (at the TB) and start fresh.
The "stock sensor assy turbo pressure" is your stock boost gauge, and also needs manifold vacuum.
mkiiichip
1,434
WI
^ that would be helpful if the setup was even close to stock, which it is not.
There a few manifold vac lines;
there is a small line at the back of the intake, below the brake booster line
one that you are currently using for BOV
one that the stock system uses for BOV (cant remember where that is exactly at the moment, but its buried)
Many use a large vacuum line (ie brake booster) and a vacuum block, to get signal to numerous components, but there are many ways to get the job done.
ToyotaSupra
Shawn
Dec 12, 2009
59
Fond du Lac
ok so do i have a MAF or just a airflow regulator, heres some pics,,,,,,,,, i dont think the hks evc is hooked up right, its prettymuch fully custom,,,,,,,,, questions - is the intercooler stock in the picture.... how do i hook up afm boost gauge, what kind of auto tranny do i have? it says M on it and is that a good idea for cooling the turbo, oil line tapped into the oil pan?
ToyotaSupra
Shawn
Dec 12, 2009
59
Fond du Lac
more pics, from what ya can see is that fpr hooked up right?
oh and when i floor it when t he boost kicks in and it starts speeding wayyyy up i hear knocking or ticking,,,,,,,, is that common or u think it has a BHG?? supposidly it has a HKS MHG
ill answer any questions or take any pictures of anything anyone wants. thx
mkiiichip
1,434
WI
You are not paying attention
NTRA08
TWINKY
Jun 10, 2008
530
Conroe, Texas
yes that is a stock intercooler. That is the return line from the oil cooler that is hooked to your oil pan. Your FPR is not hooked up right. It looks to me like you have some steel vacuum lines missing. You probably don't have your VSV's either. And just hook up a vacuum line from the back of your gauge to manifold vacuum.
---------- Post added at 09:01 PM ---------- Previous post was at 08:55 PM ----------
And if you have a manual trans and it came stock turbo. That means you have the r154. If you have an auto its most likely a A3040E.
ToyotaSupra
Shawn
Dec 12, 2009
59
Fond du Lac
my 89 is non turbo manual and 88 is turbo, u think i can switch em out without too much of a problem?
ToyotaSupra
Shawn
Dec 12, 2009
59
Fond du Lac
NTRA08;1588341 said:
manual to manual. shouldn't be hard at all. auto to manual you need quite a bit of stuff to get it done.
i have a 89 with a manual transmission, my 88 7mgte is auto, looks like i could just switch em over..... would i need to switch ecu's aswell? or get another ecu from a manual 7mgte?
oh and the knocking i think what it is is the internal wastegate from the turbo, its like cack cack cack cack ish noise
