i have an 88 and an 89 supra the 88 is turbo and the 89 is not. had an acident with the 88 and so i decided to swap over the motor and at the same time convert the car to a manual. so the swap and the conversion all goes into 89. but after i was able to put in the motor and the transmission, i found out that with the 88 ecu my headlights came on and wont go off. the car also isn't starting. it cranks but does not start. im using the 88 engine harness. i also bypassed the transmission aswell. i really need help with my car so please help me out if anyone knows anyything that i can do to get my car up and running. thanks
