I was on my way to a friends house and my gas gauge doesnt work so I ran out of gas. I put gas in my car and it wouldnt start. I replaced my fuel pump because the other one went bad. Even then the car wouldnt start. I bridged a relay above the fuse box under the hood on the drivers side. Finally i started gettin gas in the injectors. I figured since i wasnt getting gas without bridging the relay with a wire, then the fuel pump relay must be bad. I bought a new one and still no use. The car is just sitting in the driveway. :nono:
