It was 87 .... out with some friends, late summer... and the girl of my dreams drags me away from a party - say's let's go for a ride in my new car. Next thing I know were doing 135 down the blacktop... I don't know if it was the car or the blond, but I was hooked! Gimme Some More!
Several years later I ran across the MKIII car, still in great condition and always heard good things about Supra's and the unlimited possibilities for serious HP! So I took the Dive, and bought it. Now looking to get some serious - reliable - Miles on this Baby!
I come from a Old School Big Block background - Any Helpful Input is Greatly Appreciated!!!
After consulting with some folks here is ....The Build ...
Block - 7M, Crank 6M, Eagle Rods, Forged Wiseco .020, Oem Oil Pump
Heads - Mild Porting, Comp Springs, Upgraded Valve Assy Parts, Oem Cam, Valves, Timing Gears
Intake - Oem Plenum - Minus the Restrictive Airbox, Alum Pipes, 50mm Bov, Upgraded IC, 57 Turbo SP61GT (5862)
Exh - Oem manifold, 3in from the turbo out the back - no Cat, AEM Wideband O2
Motor was built by a friend on this forum - Great Work - Zero Balance Assy - Blueprinted - Nuf Said!
Other Add-ons:
2.0 mm HG, Spec Twin Disc Clutch Kit, AFPR, 660 Inj, AEM ECU, AEM Twin-Fire Mod Ing, Egr B/O, AEM Boost Cnrl, 3.5 Bar MAP, Air Temp Sensor Walbro Pump, Fluidyne Rad, Flex-o-lite Fans, Earl's Turbo Lines
Trans Re-Build to handle 600+, Aluminum D/S, Lowering Springs, Sway Bars Upgraded, Illumina II's - 17" Wheels - Just a bit bigger than stock
Potential for this combination?
What if down the road - T-4 - turbo and exh headers? Any Issues to think about now.
~Thanks Friends~
~Gman~
Finally the snow is melting here in O-H-I-O, so it's back on the horsepower path, new pic added, more to follow!
Other Add-ons:
~Thanks Friends~
~Gman~
