87 to 89 Body Harness Questions
BJ91T
810
Baton Rouge LA
Ok so I have a 86.5 NA shell (pretty much gutted to a bare shell). If I was to remove the body harness and replace it with one from a 89 would a 89 efi harness work? Would I run into any other problems?
Just an idea im pondering since the 87 efi harness is no longer in production and I have a brand new 89 harness in my room.
Thanks In Advance
BJ
gtsfirefighter
SM Expert on White trash
Sep 26, 2006
2,965
Are you talking about the engine harness or the harness behind the dash?
I've got an 86.5 GE and pretty much just turned it into an 87 GTE. I replaced all the harnesses behind the dash (what a bitch to do to). I'm guessing you would need to replace all the harnesses to make sure it would work. You can make your 86.5 an 89 but it will take a lot of work. 89 is it's own unique year model.
BJ91T
810
Baton Rouge LA
the body harness is what I am talking about since I have a brand new efi harness for a 89 I plan to swap over the remaining wiring from a wrecked 89 that I have.
ForcedTorque
Join the 92 Owners Group
Jul 11, 2005
6,099
I would first be sure that the EFI harness you have for the 89 will work for that body harness that you have. From what I have heard, there are 3 different 89 harnesses. Then, if it will work with that body harness, I would do as much research into your connectors for certain things. Chances are you will have a couple that just aren't the same. If you are good with wiring, you shouldn't have too much of a problem.
NashMan
WTF did he just wright ?
Aug 5, 2005
4,940
17
Victoria BC
make feild haress or swap some pins not worth rippng the inpore haress out ti alot fo work toyota made enw harness every year of the supra as well
BJ91T
810
Baton Rouge LA
thanks man, maybee when I get this car going i will ride out to wherever your at now (im in baton rouge) and check out the 2jz hotness.
BJ
