Hey guys...
Pulling apart the brakes on a car that I just brought home... '87 all stock 5spd turbo car with every factory option and only 130k miles.. not too terrible for $800
The car had been sitting for 5+ years and the brakes are frozen. The fronts came apart easily enough however the rear are being a pain. I pulled the lower bolt and the caliper was stiff to twist up.. took a pry bar. The upper guide pin is so frozen in the caliper that its coming out of the bracket instead of the caliper.
Has anyone had this issue before? If so, what are my options? Track down different rear brackets and calipers?
Thanks
-Chris
Thanks
-Chris
