Can you use the 89 engine cradle and 89 motor mounts to install an 87 7MGTE without having to swap different suspension in or should I give the guy the entire front assembly to use?
He may be buying some parts cars from me and I want to make sure the 89 cross member will work with the 87, 88 suspension. I guess the power steering rack may be another cinsideration also.
Any help would be appreciated.
Thanks for looking
Thanks for looking
