86.5 Updates
86yota
87
upper darby ,PA
i pretty much decided to make a new build gallery my first was..well it just sucked.
So here is my build on my 86.5 supra that started life in June 1986 months after i was born.
the original 7mge caught a rod knock and i had to find a motor to replace with i bought a 87 supra and rebuild the 7mge here are the pictures of pretty much everything ive done since.
This is a before picture.
broke :biglaugh:
This is rebuild kit i bought. pistons,rings,bearing,oil pump,water pump,timing kit and all the gaskets i needed.
The Block
New bearing in place
Pistons ready to go in
After i honed out the cylinders i set the crank.
Alright this after i put the timing belt on and got a few other things bolted on.
got the Exhaust on.
All this stuff was a pain in the butt. but still kind of simple.
New clutch gotta love that blue..:naughty::naughty:
86yota
87
upper darby ,PA
These next pictures are of the bay. I decreased and sanded it all down before primer and paint.
Then finally after about 2 1/2 weeks from start i got it back in.
still had some wiring and other bugs to work out. took about another week before she was running good enough to drive home.
Since then i had a to get a new battery, alt, and replaced the wires and plugs again.
I have also replaced the heavy 2 piece drive shaft with a 1 piece steel.
As of now this is how she looks i just have some more body work to do and then ill be painting her.
But today the drive shaft started wobbling i slowed down and stoped. Then as soon i put it into gear, The end that bolts to the Diff. riped out and left me stuck, i believe that bolts came loose i should have lock tited them bastards.
86yota
87
upper darby ,PA
so it looks like i did not snap the pinion i guess i that the four bolts that hold my drive shaft in came loose over about 3 months of installing, so iam going to buy new bolts and lock tite them any other suggestions ?
SupaMan
Want The Boooooossttttttt
Oct 12, 2006
1,101
Cape Coral,Florida
looks pretty good that rod was way beyond messed up, i have a couple of questions.
How did you like that DSS shaft before it came undone? Is it steel or aluminum? I cant really tell from the pic, Did it have any wobbles or anything before the mentioned mishap?
Also what clutch is that in the picture and how do you like it?
Im asking because im lookin for both right now and im not real sure what to go with.
86yota
87
upper darby ,PA
Yeah man that thing was knockin for like 3 months...
sorry for the late response but the shaft is steel its only weighted like 25 pounds
no it never gave me any problems kinda makes me feel more secure then the original 2 piece. i paid like 400 for mine they are on sale right now like 375 i think.
The clutch was called a stage 1 it was made by grip force i have have no problems with it at all. It came with the center bearing and inserter. I found this on ebay.
Good news is that i got those new bolts in and tightened them up real nice and everything is all good with that. My ratchet sliped off a bolt and hit me in the head full force. i have a nice gash from it. Just a little blood and sweat.
86yota
87
upper darby ,PA
Pretty much i found out that it would be good to go over all my bondo work With "Tiger hair" its like short hair fiber glass in resin already just add the hardener and spread and be prepared to sand this stuff alot. Its alot harder then bondo.
86yota
87
upper darby ,PA
I picked up a set of 17 inch Konigs from a friend with new tires tell me what you think. One on the pass. side has some curb marks but for $180 cant beat it.
SupraJDS
603
Yo man looking real good, rims are better than stock and for 180 aren't bad at all. I gotta see this Supra soon.
86yota
87
upper darby ,PA
ya that was my thoughts at first then I figured when i get my lowering springs it should shorten that cap up a little.
