86.5 supra N/A
lostshadowz
14
seattle
i have a what the titles say and my friends are bugging me to go turbo. but i want to take this car asfar as i can N/A. i know where to get some parts and stuff online but i was woundering if any onehas or knows a site that could help me with chosseing the parts that would best go with my engine for n/a. my engine is a 7mge but i got it from japan to replace the one that was origanaly in it.
thank you for your time
lagged
1991 1JZ
new rochelle
i have an 86.5. check out bishops section at ma70.com and drjonez's site 4cefed.com they both have some NA performance sections.
IMHO however, youre wasting your time. go turbo, that what i did with my 86.
SupraMario
I think it was the google
The Farm
Or go 1 or 2jz. 7mgte's seem to be getting rarer and rarer.
2jz has easier to find replacement parts because its newer.
just throwing out that option, its more expensive tho.
SupraMario
The Farm
IJ. said:
1600 kg car + 3 litre NA motor is never going to be fast no matter how many $$$ you drop on it!
Weight is against you.
NAWWWZZZ + downhill + hurricane = mid 13s. LOL
ToyoHabu
261
Huntsville, Alabama, United States
You would need a LOT of technology to get any appreciable gains in power.
Things you could do
1. New tubular exhaust manifold
2. New Down pipe and exhaust
3. Port and polish head (major bucks very small increas in power)
4. New Intake manifold, perhapse a dual runner like MR2
5. Bump compression to near 10 or 11 to 1. ( would need to watch for detonation mayby add nock sensor ?)
6. Stiffen Up the valve train in order to up the RPM range.
7. Adapt some sort of Variable valve timeing (can be done but $$$$)
After you have done all this(after youve become buddies with Donald Trump that is) You will have a monster 300 HP NA Supra. (this is what the IS 350 is pumping out)
In all serousness there is no justification for NA anymore. Turbo technology has completely ereased any of the early turbo problems like serious lag.
AGlobalThreat
Acceleration
Apr 4, 2005
991
Santa Clarita
Coming from someone who has put a ton of money into his NA and bought nearly every mod possible for it, I must advise you to go turbo. Even with all the mods, a healthy engine, and enough weight reduction to get my car under 3000 lbs, I still lose to STI's, C5's, and just on Saturday a Gallardo. Already started the 7mgte fund, the NA engine is simply not worth the time or money.
lostshadowz
14
seattle
thanx for the advice. i'm going to do anything and everything i can n/a just to see how far i can take it. just cause i want to see my self. more expansive yes but it's somthing i wanna do.
after i end up blowing this engine i'll just go to maybe a twin turbo engine out of a 97 or 98 supra.
thanx again for the help though
shaeff
Kurt is FTMFW x2!!!!
11
Around
i dropped a GTE in my 86.5 :) never looked back.
-shaeff
