B
boogiesurfer
Guest
:1zhelp: This is my first post on this forum. I've been to "car talk" before, and I still can't figure out what's going on with my rebuilt 7MGE. The shop that rebuilt the motor is a transmission shop, and the owner's brother was rebuilding 7MGE's "on the side". I thought $2500 for rebuild and new clutch was a great deal. However, it took them almost a year to get it completed :ugh: I still don't know what kind of rings were installed or any of the technical stuff other than the machine shop "balanced the engine, weighing and balancing rods, etc." When I first took my vehicle to this shop, it took 2 weeks, and it was done. It ran great, but there was one problem, when the motor was cold, and started, there would be a slight "knocking" sound on startup. I took it back, and it took another 10 months before they had it completed! At first the mechanic was scratching his head, and had a difficult time determining where this "start-up knock" was coming from. First thought the heads, and different heads from the machine shop were installed. Still had knock, so they apparently went to the block, and said that the machine shop had not done the crank properly. I should interject here that the original problem was the crank and it had to be replaced, and they didn't utilize my original block, but another block and crank. So when they still had start-up knock, they sent my original block with a crank to the machine shop, and it was finally completed, "balanced", and installed.
Even after all this, they couldn't get it running good, since it was sitting for so long in the shop, and they really couldn't figure out the "electrical" side of things. So I had to take the vehicle to another mechanic to work on the "top end" i.e. wiring harness, electrical components, and found that the computer was fried. My friends can't believe how much I went through to get this Supra repaired and running!
After finally getting it to run well, I realized that I was adding approx. one to 1 1/2 quarts of oil a week (30w). No major smoke, no deceleration smoke (valve guides), and only a "haze" on hard acceleration out the rear (the rear bumper has a thin film of oil after a couple days driving). My new mechanic told me to run 20-50w oil and it could make a difference. It does seem to be consuming a little less oil now, but still 3/4 to 1 qt. per week. Before changing to 20-50w the oil dipstick would always be "popped" out approx. 2-3", and the mechanic said this is indicative of "blow-by". After changing to 20-50w the dipstick many times is not popped out as much, and many times not at all.
I am the original owner of this Supra, and I'll never forget how far ahead of its time it was in 1986. The car runs great, and I'm very happy with the performance, but this oil consumption thing really frustrates me. Is there anything else I can do short of tearing the engine apart again? One last thing, another mechanic pulled the plugs, and said that the #4 cylinder plug was "carbonized". :icon_roll BTW we've done extensive checks for oil "leaks" and found nothing. Thanks so very much in advance for any constructive advice.
