So I'm swapping an 87 turbo motor into an 89 shell, and I have the 89 harness already, but wiill I need to replace the tps with the 89+ part?
Jeff Lange;1513348 said:Both N/A and Turbo used both types of TPS at different times during production. Depending on month/year. They are all electronically interchangeable. The only difference is the orientation of the tangs that turn the TPS on the throttle body.
Somewhere on here I posted information about what years/models used which type.
Jeff
reincaster;1513366 said:So I will be fine right? Thanks Jeff!
CRE;1513368 said:You're not even swapping the TPS? Then yes, you're fine. otherwise you just need to make sure the tabs in each TPS is clocked the same way. Seriously people, this isn't as big of a deal as most seem to think.
