85 supra door unlocks and then locks again with alarm
ocjmakaveli
illinois
Well this being my 6th remote start alarm I'm confident I've done everything how it should've been done.
Now after about a week after the install their is an issue with the alarm.
What happens is when I unlock thedoors witht he remote the locks unlock but then quickly lock again.......
At first today while i was diagnosing the locks would keep locking no matter what even if i pressed the unlock button on the door the locks would quickly lock back up.
So instead of spending $40 plus on a door lock control unit I just grabbed 2 relays and figured it out after an hour so I now have 2 relays instead of the door lock control relay.
Things got better but not perfect now sometimes they'll lock back sometimes they won't. The good thing though is now when i use the button on the door they always stay unlocked they don't lock themselves again only about 40% of the time when I unlock with the alarm the doors will lock themselves again and then I have to lock the doors and unlock until they stay open usually 2-3 tries now. Before i replaced the relay I actually had to unlock the doors and quickly open it before it would relock about 2 seconds later.
It's a 1985 toyota supra I would really like to get this fixed I'm out of ideas really I set some of the options of the alarm off like automatic locking etc. parking lights staying on for a few seconds after is off also.
I thought about the switch making contact at all time but it really doesn't seem that way since this is an intermittent problem. I will most likely replace it anyway for the hell of it.
Last thing I didn't connect the disable alarm wire because the first time everything worked fine and I wasn't able to find the damn wire my guide said I needed.At least the colors don't match up and I tested other wires without success.
