7mgte wont start need help
Konstantin
Portland OR
the car cranks over fine. however there is no power to my aem ems but everything else works. when the key is turned off a few things on the dash are still lit up. so i am thinking it might be short somewhere in the harness. i have no idea where to start. need help
black91turbo
Formerly black87turbo
Apr 27, 2006
1,064
Jacksonville, FL
I was going to suggest checking codes.....but you have an AEM so I dont quite know how that works. Check your ground? Whenever I have a problem like this I find that 9 times out of 10 its is usually something that I worked on last.
shiftysupra
180
Tucson, AZ
make sure to check everything that you have worked on before it wouldn't start. An improper ground is usually the cause of it not starting
