7mgte with N/A electronics
bountykilla0118
In Pursuit of 500rwhp
Jul 16, 2005
1,088
Atlanta GA
can the 440's be used with the n/a harness and ecu? There was a guy that posted a thread a long time ago .... i searched but i could not find the thread i think it was "no boost cut". Well anyways he was using the n/a electronics the flapper afm, wire harness and ecu with the 7mgte
8,895
They can be plugged in.
The 89 and later 7MGE uses high impedance(resistance) injectors. The 440's are low. Working around that seems somewhat easy.
However, if you are in pursuit of 500rwhp, don't use the naturally aspirated electronics. You will be shoveling shit against the tide as they say.
bountykilla0118
Jul 16, 2005
1,088
Atlanta GA
got ya i when i get close to 400rwhp i will be using MAFT pro or e-manange. i was just wondering about the electronics and what do you need to make it all work.
tubbie
Yes, powerful Jedi....
Apr 4, 2005
821
Hoschton, GA
I was using 440s on my NA electronics turbo motor. Worked just fine, but while idling, it was running quite a bit rich. Couldn't tune it out with my HKS AFR.
