7MGTE With a list of problems :(
Mk3Shogun
Tx
Well its been a while but here i am, OK to start off the bat is the following codes 12, 34, 51 not only that but grey smoke as well i will post the vid soon.
All started when my two front inter-cooler piping got bent and the other side with a hole in it, I went to start up the car to park it turned it over and white smoke blew out for 3 mins then stopped, i was thinking that might be from the morning start but when I started it again to move it from my wife's car (Mid day) it did the same thing...
So i ordered some pipes to fix my two front inter-cooler piping, put them on and took the car for a test drive to see how she runs Pulled hard but still a boost leak (Car jerking) CEL came on and gave me the codes then came back and let the car sit but rev'ed it and grey smoke http://www.youtube.com/watch?v=l7-T663tamU&feature=youtu.be that's the vid.
Mk3Shogun
Tx
So your saying is it ok for grey smoke and white smoke to come out on start up or reving.
peste noire
266
los angeles,CA
there shouldnt be any smoke besides condensation(not really smoke but it looks like it lol) and as far as the video, it says its private so i couldnt see it.
but fix your codes.
Compton74
355
Long Beach
White smoke ususally means coolant/water, black blue or gray smoke usually means oil or fuel. If your car runs rich in boost it will puff black smoke. Take the car for a test drive and see when it smokes, hard acceleration, deceleration and see what color it is. You could have valve issues, you could be experiencing really bad blow-by, or your turbo seals could be going out.
Mk3Shogun
Tx
but fix your codes.
Vids back up
*Update* Turbo seals were worn out and in process to replaced.
