7mgte vs 5mgte /w 7m head
D
drumminforev
Guest
is it possible to put a 7m head on 5m
and what are the difference to go 7m that are better than just boosting a 5m
D
drumminforev
Guest
Why? 0.2L sure it will make a little more torque, but for cost to HP ratio is what i am talking about here
specifically why is it better other than literage. Yes its 4valve per cyclinder but Boosted how much will this matter, so dont say that it "flows better" unless its really significant
pimptrizkit
thread killer
Dec 22, 2005
1,572
vancouver Wa
i have wanted to do this aswell, in theroy, well my therory, it's possible, and you would have a 2.8L 24v turbo motor. which would be teh shit! lol
if the bore's are the same dia, best to use the turbo piston's
D
drumminforev
Guest
I will be upgrading to forged pistons and rods. Does anyone have any real info on what makes the 7m better other than 2wice the valves
rocketman
57
md
i might be able to help u get parts.. i was in the junk yard yesterday.
i seen 10 supras there i am going back today .. pm me ifu want more parts
D
drumminforev
Guest
Well i am a mk2 supra guy so mostly i need mk2 parts and everything neccesary for the swap 7mgte
D
drumminforev
Guest
what years are later model, and what does reinforced mean...thicker sleeves? and how much would any of this matter for 400whp
(oil squirters can be added to the 5m right?)
bigaaron
4,692
Pomona, CA
www.driftmotion.com
The first post in my thread has comparison pics of the late model 7m vs 5m vs 2jz. It would not be possible to add oil squirters to the 5m block.
D
drumminforev
Guest
Does it matter then to have oil squirters. Which way is faster for less $? 5mgte or 7mgte
bigaaron
4,692
Pomona, CA
www.driftmotion.com
drumminforev said:
Why is that...if the 5m outflows the 7m
The 5m head doesn't outflow the 7m head without costly modifications.
The 5m rods are longer and thinner. read: weaker
The oil squirters are not a must, but there is a reason they are on the turbo motors.
The shorter stroke will be good for higher rpm, but the reduction in displacement will decrease horsepower slightly.
I think the payoff will be in the performance aspects like throttle response and smooth power delivery.
