7mgte takes alot tries...
Falken
294
Los Angeles
7mgte takes alot of tries to start it... Every overnight I try to start it but it takes like 10 mins cranking it, and once it starts it runs good and everything, once off I can turn it back on like nothing, it just takes long when the car been sitting for long periods of time. I dunno what it can be I'll appreciate all the help.
87M-GTE
Slow
Sep 12, 2007
1,705
Milwaukee WI
Condition of plugs/wires? Cold start injector hooked up or working properly?
Those are a few things to check..
May want to give it a compression test while your at it
Sam
modmonster2008
mod crazy yo!
Sep 9, 2008
1,051
Seattle, WA
leaks in the intake hose? air/fuel meter, o2 sensor, plugs and wires like mentioned above, usually the cold start switch on the thermo housing if removed will still make the car start but run at a high idle, just check those other ones as well
Falken
294
Los Angeles
ok thanx alot, gotta put my head in there and check out everything
---------- Post added at 05:18 PM ---------- Previous post was at 05:11 PM ----------
i really dont have that many mods... just bigger intercooler and exhaust and turbo timer and radiator with elecrtric fans, and now its smoking a bit when i rev it over 3000 rpms.
---------- Post added at 05:26 PM ---------- Previous post was at 05:18 PM ----------
can it be the coil pack sequence the one that connects from the igniter
joel903
314
Conover,NC
I had this problem with my 300zx twin turbo a long time ago. It ended up being the stock "fuel pressure regulator". My car would take like 5mins to crank over and turn on and it was running super rich all the time as it was being flooded by fuel constantly. Check your fuel pressure regulator and that might solve your problems.
Falken
294
Los Angeles
here is a lil video of the problem i am having.
[video]http://s17.photobucket.com/albums/b56/ARELI06/?action=view&current=MOV04383.mp4[/video]
Falken
294
Los Angeles
ok i switched out the knock censor and afm rewire some bad wires and the car is running great now :) the only thing is it idles lil low at 600rpms
