:1zhelp::cry: I was having a problem with fuel cut, and someone suggested TPS, so i changed it, but didn't have the tools to properly calibrate it. I was under the impression that the car would still run is the TPS was improperly calibrated, but it wouldn't run correctly. After changing the tps i found a huge hole in my IC piping, so i replaced all of it with SS pipes. I removed my A/C, and cruise control. This is all i have done since the last time i started my car. Currently the problems i'm having are: Motor is cranking, but won't start. i can smell gas from the exhaust, so i don't think fuel is the problem. I stuck a screwdriver into the #1 plug wire, and i'm not getting spark. For some reason, my Wipers won't shut off. I have the motor unplugged because it was irritating me, but as of last night, they were constantly on, even when switched to the "OFF" position, and the speed would only change by a very minor amount when i toggled the stalk. My main problem is getting it running, but input on the wipers would be helpful as well. Does adjusting the TPS effect my timing? Would resetting my crank timing and resetting my cps help me getting spark? I can't think of anything else other than a bad relay of fuse, but s far as i can tell all my fuses are good.:: angry :::: angry :::3d_frown::3d_frown:
