Has anyone used megasquirt and removed 2 teeth from the factory CPS (24-2) to get a steady RPM signal? I'm stuck getting an rpm signal that bounces and hits 0.. Can't figure out what the problem is at this point!
speedfreak426;1774184 said:Because the DIYPNP is not actually PNP at all. The harenss physically will plug in, but there are many modifications to be done to get it to even fire up.
With MS you can build the system to your own specification using any ignition, fuel, sensors, setup that your heart desires
