7mgte injectors leaking!!! help please
suprakidd
313
Glendale, Arizona, United States
ello guys i have issuses (with my mk3) lol. just to bring you up todate. i took the cams offto replace the cam seals and put it back together and bam! from what i can see injectors 2, and 5 and leaking maybe more but at this point idk any help will be appricated thanks a billon.
- ps i took everthing off from valve covers to uper intake to injectors.:1zhelp:
toyotanos
What will we break today?
2,841
Coon Rapids, MN
Sounds like your o-rings are done! easy to replace, though!
They are leaking from in between the fuel rail and the injector, I assume?
toyotanos
2,841
Coon Rapids, MN
Umm, there is no fuel that goes through the head. But, I still think it's the O-rings that you are in need of. You will need 6 -orings, and 6 insulators to do the job right (and avoin vacuum leaks)
http://www.cygnusx1.net/Supra/Library/EPC/291420/catalog.aspx?F=2211&P=2
Look for part numbers 23291 and 23250B
Actual parts are
O-ring- 90301-07001
Insulator- 23291-41010
Get 6 of each!
If you feel the need, take some very good macro pictures of where its leaking and we can try to pinpoint the source, or at least tell you what tests you can to to pinpoint it! :)
supersupramk3
average joe
Mar 29, 2009
145
sacramento, CA
suprakidd;1688288 said:
are you sur the injectors dont sit against the head? isnt that where they spray the fuel in??
They dont sit on the head....they are on the IM (intake manifold). To solve your problems take off fuel rail and change out o-rings and insulators. You might have pinched or squeezed the rubber rings or insulator too much or unevenly, thus leaking.
