I have a fresh build on a 7mgte...ran great for 75 miles...then while driving in town, I pressed on the clutch and it died...I immediately let off the clutch and it started up again....but when I pressed on the clutch again, it died and I could not start it...I coasted to a parking lot and tried to start it. It sounded like it had a dead battery and did start, but bogged down right away and died and then I could not start it even though it was cranking fine. I let it set for 7 hours, came back and it cranked but would not start....I took some codes and found 12 and 21....12 is CPS so I wiggled the wires and it started, but died again when I pressed on the gas. I did get it started again, but it bogged down and died. I tried again and it cranked like a dead battery and would not start.
I let it set for another few hours and it towed home. Took the codes again and they were the same, 12 and 21.....I wiggled the wires a bit, and pressed the CPS clip tight again. It cranked like it had a dead battery again. I checked and the battery was over 12 volts, nearly new battery. I tried again to start and it started without a problem. I backed it out of the shop, then back in....no problem. I revvv'd it up and it was fine, it idled at about 650 until I turned it off after over 5 minutes....started it again without problem....
Read many different postings that say to change the CPS, but I moved the wires all over the place while it was running and it did not have any effect at all. Checked the codes and they still show 12 and 21....Does anyone have any ideas?
