7MGTE: Couple Questions
s.u.p.r.a
52
Roswell, GA
Hey all,
Just got my car running with my new engine and have a few questions
1. Will tranny fluid leak out of the speedo cable connector on the end of the tranny if the cable is not attached?
2. Will anything bad happen if I temporarily (couple weeks) hook my afm straight onto the 3000 pipe?
(I'm trying to get my IC piping to fit properly and so I thought this might be a safe hack to run without the turbo)
Thanks for any info,
Alex
AF1JZ
Almost civilian status...
Jun 26, 2006
3,109
Fredericksburg, VA
You cannot do it.
rumptis
나는 제프가 당신을 사랑
Aug 16, 2005
814
North Vernon, IN
1. Not sure.
2. It would basically be like running a NA with Turbo Electronics, should be fine but don't expect much power.
Datsrboi
Loud pipes Save Lives
Jul 31, 2007
797
Haltom Texas
^^^ I would think that you will fry your turbo since theres no pressure/boost in your turbo so your waste gate will never open to relieve that turbo. Also correct me if I am wrong but doesn't the turbo require pressure on the internal plates to keep the oil from leaking out?
rumptis
나는 제프가 당신을 사랑
Aug 16, 2005
814
North Vernon, IN
s.u.p.r.a said:
(without the turbo)
Not sure what this means but it sounds like he doesn't have his turbo installed and thats how I took it.
If he tried to run it this way with his turbo installed that would be bad as you say.
