7mgte build input
7m90jt
17
kansas
Hello everyone, I am new to the supra game and automotive performance. I have some knowledge about cars but mainly just basics. Now I dont own a supra yet but do plan on buying one after I get this 7mgte motor done. Now I just wanna see if I can get some input from you guys. My goal is 500rwhp. Already have a cylinder head at the machine shop now getting the stock valves cut to seat right, along with new valve springs,valve springs and milled straight. I have a block being sent to me this week. I am planning to leave the bottom end stock, just honing out the cylinders and new piston rings. I also have a crank that has been polished along with matching bearings. I am planning togo with a 61 or 62mm turbo Running about 20psi with t4 mani along with 550 injectors and upgraded fuel pump. now that is just what I am planning to do for now. But any input would be great in saving me time,money and what parts should I consider going else with. As for money goes I have a decent amout to play with as time goes on but not trying to spend it on things I might not need. Thanks for any input as it is greatly needed.
Fuel pump.
Afpr.
Maft pro and get tuned.
500 is kinda stretching the limit with 550's but it can be done.
Also make sure the block and head are machined for a mhg try for 30ra or better.
7m90jt
17
kansas
hvyman;1849818 said:
Fuel pump.
Afpr.
Alright well thanks for input. But me being new to.this and all what do you mean by 30ra or better? will something need to be done by machining head and block to make mhg seal right
