Problem im having s i pulled my car outa storage and she started having driving concerns. under wide open throttle everyonce in a while the car will start bucking and misfiring kindof. The car bucks back n forth and backfires. my AFR is at 11:1 while at 8psi of boost. I have a full 3" turbo back, upgraded intercooler and walbro 255 fuel pump.Stock ct26 Running greddy electronic boost controller. I havent changed anything in my setup yet it randonly decided to do this. Previously i was running at 10psi no problem. Ignition timing is set plugs are gapped correctly, no check engine lights. I know it is running too rich but would that caouse it to buck underboost? Also my car backfires alot under decel. any suggestions?
