7MGTE Boost Issue
MKIIITurbo88
23
Michigan
I have installed a HKS EVC and whenever i get above 6psi, i get boost surge; I have my target boost set to 10 psi, and it will hit 10, drop to ~7, back to 10, then to 7 etc.
When I un-install the HKS, it only runs 5psi. Is this common for wastegate pressure?
I'm beginning to think I may have popped the diaphragm in the wastegate actuator;
Any thoughts?
MattTerror
28
Ohio
MKIIITurbo88
23
Michigan
Compton74;1861637 said:
is the car automatic or stick?
Manual transmission
Orion ZyGarian;1861686 said:
Thanks for the write up; I'll try this and see if it resolves my issue. However, I find it odd that this goes against the manufactures instructions on how this think should be hooked up. Also, it's not that my boost is tapering off, it is surging, like this:
Orion ZyGarian
Jeff Lange wannabe
Apr 2, 2005
1,490
Sarasota, FLorida
www.suprastore.com
I'm not entirely certain that it will fix it, but it might at least help. I'm also not sure why manufacturers say to use the nipple on the compressor housing, when science says the density of the air after the intercooler will change how it affects the boost signal. Maybe they dont expect lots of boost, and through a bar and plate design..? I'm just relaying the info I have found. In this case yes, you'd block off the compressor housing source.
Turbo Habanero
4,229
Tucson,AZ
That's awesome info
Thanks Orion.
I have a few questions.
So I'm still running a CT26 turbo and stock wastegate setup.
Currently setup up using the factory nipple on the turbo.
My question is
Since ill be running one line from the wastegate to the solenoid and the other to from solenoid to intercooler pipe closer to the throttle body, now what do I do with the open nipple on the turbo ?
Should I just put some vacuum line and block it off with a screw ?
I posted this same thing over in your thread Orion and then realized that maybe I'm not suppose to post under that section.
IndigoMKII
2,181
Madison, Virginia
Turbo Habanero;1861989 said:
That's awesome info
Thanks Orion.
My question is
Why not just hook it back up to the turbo? You'll get a more 'accurate' reading as to the output of the turbo itself and be able to see the PSI lost in the IC/piping.
Turbo Habanero
4,229
Tucson,AZ
I guess I'm not understanding something correctly...
Stock the port on the turbo has a line running to the port on the wastegate. With this mod ill be using the wastegate port and a new port on the intercooler pipe in place of the port on the turbo.
So thus leaving a open port on the turbo correct? So i was wondering what I should do with this port?
I thought the whole point of doing this mod was to avoid boost drop off?
Turbo Habanero
4,229
Tucson,AZ
IndigoMKII;1862043 said:
Doing that will avoid boost drop off but also make the turbo work harder per say to keep up with the drop off.
So what do you recommend ? Is it going to be bad for the turbo in such a way one shouldn't do it ?
I don't have much boost drop issues but i have a avcr that i can adjust by rpms to help keep the boost where I want it.
teedoff00
14 psi boost
Dec 5, 2007
297
Selah, WA
Try reducing the gap on your spark plugs, if they are set a stock gap. You are likely to to get surging at higher than stock boost levels without reducing the gap. Happened to me a few years back, may be worth a try.
IndigoMKII
2,181
Madison, Virginia
If you don't have a huge PSI loss in the IC/piping then I'd leave it like normal.
MKIIITurbo88
23
Michigan
Thanks all for the thread bombing - back to my issue. Besides the ic pipe 'mod' (rather than using the compressor housing nipple), and potentially re-gapping the plugs, what else could cause surge? Is there an easy way to test the BPV and then wastegate actuator?
I initially thought I might have a boost leak, but this does not make sense as 0-5 psi holds steady (wastegate pressure); after that, I get the boost oscillation.
IndigoMKII
2,181
Madison, Virginia
Does the 0-5 psi hold steadily with a boost leak test? Or while you're driving?
MKIIITurbo88
23
Michigan
Driving - holds 5 dead steady when 3/4 throttle - 100%; that's when I have the boost controller set to 5psi or off (running wastegate pressure). As soon as I try and exceed 5psi, I get the oscillation
IndigoMKII
2,181
Madison, Virginia
Have you tried to boost leak test your piping? Sounds like you've got a leak opening at higher PSI.
teedoff00
14 psi boost
Dec 5, 2007
297
Selah, WA
You can test your WG actuator with any bicycle pump with a gauge. Stock WG crack pressure is around 5.5 to 6psi if I recall correctly. However, if you your wastegate actuator is seized, you will either never build boost, or build way too much. Don't think this is your issue. Try the plugs, I was stuck until IJ pointed me in this direction and it 100% fixed my issue.
Good Luck!
MKIIITurbo88
23
Michigan
Good Luck!
My only doubt with this is that it only occurs sometimes; If the plugs were the issue, this should happen anytime the car is under boost. It holds fine at 10 psi, and then out of nowhere, it will hit 10, and oscillate between 7 and 10psi
